Post Milky Way Greek Buttons PSD's
Just finished them, so here you go
I made them for the Green colored buttons, so if you need them in another color a little Photoshoping should do it.
As the font you're using doesn't have Greek, I had to change it and its included in the .rar file.
If I'll get a little more free time, I will make the standard ones to and upload them here.
MilkyWay_GR_psd.rar
Filename: MilkyWay_GR_psd.rar
Filesize: 305.97 KB
Downloaded: 423 Time(s)
jpavlySend private message
Post Re: Milky Way Greek Buttons PSD's
Thanks jpavly,
you can create one psd and slice the buttons you need.
If can translate this, we would create other buttons too
http://www.icyphoenix.com/viewtopic.php?f=5&t=789
Thanks so far for your work
Thank you very much, if you can create a full working set I will then add your buttons in ColorizeIt.
I'm sorry but my Photoshop skills are limited..
I don't know how to use slices.. Could you provide me with another sliced image? I'll look into it and prepare it.
jpavly wrote: [View Post]
Sure... try to take a look at this:
http://www.icyphoenix.com/viewtopic...&p=28456#p28456
Sorry for my long absence, Greece and summer = paradise, so I was out of Internet reach for some time
Here are the Greek buttons, I used the UB-Omnius font, which seemed pretty much the same with yours but for some reason my Photoshop could not render the plain font, so I used only the Bold.
All fonts are included in the .rar file.
Milky_Way_Greek.rar
Filename: Milky_Way_Greek.rar
Filesize: 196.27 KB
Downloaded: 273 Time(s)
Thanks jpavly,
with you psd I have done the png. Great work and thanks.
MilkyWay_Greek_BB3_png.zip
Description: MilkyWay_Greek_BB3_png.zip
Filename: MilkyWay_Greek_BB3_png.zip
Filesize: 47.52 KB
Downloaded: 271 Time(s)
