Hello people
I'm looking for a membership card for my site so that users can register where they come from, with age display, a photo. Is there something like Googlemap also for the ICY system? would be really great.
You might also want to take a look at the Phoogle (Google) Map. I use the Phoogle Map and it works great!
Hello,
thank you for their quick response. I'm looking for exactly a world map for members, not for visitors to the site. I think the "Phoogle" is the right one. Thank you again - should I have any problems with the installation, do I sign up again.
Re: Member-Map / User-Map
That's odd. That link should take you to the 2.0.x Modifications Forums. I believe version 1.0.5 of the Phoogle Map should work. I looked at the install instructions and everything looks as if it's supposed to.
The time now is Wed 25 Feb, 2026 12:25 • All times are UTC + 1 Hour
