SOLVED - Users Cant Register
Subject: SOLVED - Users Cant Register
Dear all, im having a problem on my IP. When you go to register, its says:
Usted ha efectuado demasiados intentos de registro. Por favor, intentelo de nuevo mas tarde.
Im using 1.2.0.27 based on phpBB 2.0.23
I ve try disabling all CTCracker but still the same
I also delete all cache files, but still the same
Could you give me a hand?
URL: http://www.nvram.com.ar/profile.php?mode=register
Subject: Re: Users Cant Register
what this in english?
New Player wrote: [View Post]
You've made too many attempts to register. Please try again later.
ACP--->Configuration--->Server--->Disable public blacklist IP check upon register = Yes
Try it.
I ve already done that.
Any other idea?
Regards!
Inactive User
ACP > Ctracker > Registration Restrictions / attempts ? (Something like that). :P
I ve disabled all CTCracker :(
Any other idea?
Inactive User
Clean all caches for your forum, and optimise the database. ?
After that it's Err, Umm time? :mricy:
Dear All, ive found the problem.
The problem was that i was using VARNISH on my server so, it allways take users address as localhost :LOL:
Thanks for helping me
Inactive User
Thanks for the feedback, as I'm sure that there will be other instances of this problem in future. 8)
Subject: Re: SOLVED - Users Cant Register
Locking and adding to faqs index.
Generation Time: 4.1014s (PHP: 1% SQL: 99%)
