Hi
My 1. Question is i changed the language in the ACP from english to german nothing happens i cleared the cache nothing happens the language was english than i deleted the english language folder and sudenly everything was German? But i cant delet everytime the languagefolder:D what can i do to fix that?
My 2. Question is where can i change the charset becouse all the ö and ü where shown with the german languagepack so: �
thx
EDIT:
Ok i fixed it!
2 Questions
Subject: Re: 2 Questions
Can you explain what you have done, please?
It maybe useful for other users :wink:
Sascha833 wrote: [View Post]
It's a safe bet that he/she has installed the German Language pack as Default in the ACP and didn't go to their own profile to change it there. :shock:
And by deleting the English Language, the board defaulted to German for all users anyway. ;)
Yes thats right:D i tryed to clear the cache ,edit the database everything but i forgot to change my profilesettings very stupid^^
And the problem with the ä and ö is very easy to fix.
Go to your Apache configfile and search for AddDefaultCharset utf8 or so and replace with that AddDefaultCharset ISO-8859-1 than the english and german language should work oh and dont forget to restart you apache ;)
Lopalong wrote: [View Post]
You're no Orphan - Been there, Done that - more than once or twice too. :mricy:
Sascha833, you are talking about apache, so I guess you are working on localhost or within a VPS/Dedicated.
If you move to a shared you will not be able to make so.
Generation Time: 0.0812s (PHP: 20% SQL: 80%)
