Post SOLVED - How To Change Home Logo? Help
How Can I Change That Logo And Put One Of My Own???
logo
S-1Send private message
Post Re: How To Change Home Logo? Help
Please use search for such things, you will find a lot:
http://www.icyphoenix.com/viewtopic.php?t=4001
Get the logo route and delete untill ip root. Open it on your FTP and remplace the image.
In the ACP
i can't findd it
Can u show me where exactly i can upload the img code to ?
and also give me and example of how the img Code should look like ?
thank youu
That is not at the ACP.
You have to go to the image folder on your FTP manager.
S-1 wrote: [View Post]
logo
I dont know if you mean that but go with your ftp client to /templates/mg_themes/images/ice/sitelogo_small.png    and replace the sitelogo_small.png with your logo wich should have the same name and ofcourse with all the themes you use not only for ice
Sascha833Send private message
I did upload sitelogo_small.png to the FTP with my own pic.
But it wont come out on my forum
No picture will come out now, theres just a link that says "Home"
Where the icy phoniex logo was at now.
Whats the issue causing this that i can put my own picture?
i follow all the steps.  templates/mg_themes/images/ice
I also renamed my pic "sitelogo_small.png" but wont work =((
someone help.
ALSO, i deleted all the
and that link that says "Home" still shows onmy sitelogo.
it apears with this code in the image properties: "/templates/mg_themes/images/white/sitelogo_small.png"
but there is no such file because i erased it. =/
Can someone tell me whats wrong please.
thankkss
I see that you have done it. Your Logo is shown.
But it's to high (175px) better would be 150px or you have to change something.
If you want to change backgroundcolor to white or your logobackground from with to these orange, let me know.
ohh. okay(:
but, i have no clue how i put that pic.
i mean i know how i put it there and evertuthing but when i try changing it
it just goes blank. this is the second time the picture comes out
after 20 attempts
It sounds like you have uploaded the image file in the wrong format - Try uploading it in Binary Format.
I did, and it won't work
i know im such a bother sorryy.
im just trying to make my forum look great
can someone assist me and go on my database and fix it please?
thanks you
bye
It has nothing to do with the database, it's strictly template files.
re-upload all the original theme files to mg_themes and the image files to the proper folders, then post a link to your forum.
There it worked!
thanks verry much =))!
but en the ACP
i changed from "Milky way" to Icy Phoniex"
but when am logged in, i see Milky Way and my old logo.
and when im not logged in, its in Icy Phoniex with the new logo i want.
why is that occuring?
Four things
ACP >
Configuration > Site > set the default theme.
Styles & Templates > Check that the Default theme is correct.
Your Profile > Set the theme you want use as your default. (Thats why it's changing when you log in and out)
Clear your browser cache and cookies - and you should be right to go.
Upload your "New" logo to all themes "Colour" (image) folders so that they are all the same.
Moved to Templates and Styles.
