Hi
Is there a function or way to limit the disk and traffik quotta for the albummod like ein the downloade AEF mod?
Or is there a albummod wich allowes to limit these things?
SOLVED - Albummod Diskquota?
Subject: SOLVED - Albummod Diskquota?
Subject: Re: Albummod Diskquota?
Currently you can only set maximum number of images per category and maximum size of images... which is some under aspect similar (but not exactly the same!) to have a disk quota... :roll:
In Icy Phoenix only the new Download and the Attachment have quota settings per users.
Generation Time: 0.1064s (PHP: 15% SQL: 85%)
