Header Banner Not Changing [SOLVED]
Subject: Header Banner Not Changing [SOLVED]
I used the IP Colorize to turn the IP theme to Green. Every other things changed but the banner isn't
Take a look at: http://www.naijapositiveclub.com
What can I do PLEASE!
Edited by Lopalong:
Fixed the url /// - Moved to Templates and Styles.
Inactive User
Subject: Re: Header Banner Not Changing
The Banner did / does change colour, but obviously not to the colour you want. :(
The banner is in contrast to the rest of the layout so therefore it will always be very different. If you want to change it to a different hue and density that you want, then you will need to edit it in a graphics programme.
try use this one if you like it
top_header
replace your with this one in templatesmg_themesimagesicetop_header.png :wink:
Limun,
YOU ARE GREAT!
It worked PERFECTLY well.
Thanks my man. :)
Generation Time: 0.181s (PHP: 9% SQL: 91%)
