SOLVED Removing The Links Bar In The Forums.
Subject: Removing The Links Bar In The Forums.
I want to remove the links bar that is place at the bottom of the forums. Can someone tell me how?
Subject: Re: Removing The Links Bar In The Forums.
*slaps forehead*
Can't believe I didn't see that.....
Thanks :mrblue:
Thanks :mrblue:
Generation Time: 0.3019s (PHP: 10% SQL: 90%)
