1.2.0.27c Error After Update
Subject: 1.2.0.27c Error After Update
i try to update to the version 0.27c, but after the update, the header image, and the top menu disappeared....
my web is:
http://www.anime-0x.com
i try with my backup for the template files, but.... not workin.
I only have installed the activity mod.
need help....
and sorry for my bad english xd
EDIT:
:cry: well i solved the problem with a backup for the file, includes/page_header.php
Inactive User
Subject: Re: 1.2.0.27c Error After Update
I find this somewhat odd because the header image and Top Menu are controlled by the overall_header_*.tpl of the theme, and the .css for the same theme. ?
There is no upgrade in either the "27c Cum Patch or the 27c patch files only" for that template.
You also say that you have fixed it with a "Backup" file for includes/page_header.php - Is that a file from a previous version, and if so - what version?
my version of includes/page_header.php is 0.27b
maybe is for the "adv cms menu" mod? (but if i put the file page_header from icy 0.27b work)
the theme is a black pearl with "colorize it". i think
Inactive User
Thanks for the feedback. 8)
If you are currently running with includes/page_header.php v0.27b Then all should be ok, because there is no includes/page_header.php upgrade file in the Update to v0.27c ?
Generation Time: 0.0998s (PHP: 27% SQL: 73%)
