Post SECURITY - CBACK CrackerTracker Has Detected A Potential Attack.
SECURITY ALERT » » » »
CBACK CrackerTracker has detected a potential attack on this site with
a worm or exploit script so the Security System stopped the script.
Goto ACP > Cracker Tracker > Log Manager > Worm & Exploit Protection > View
Note the entry that has been blocked and do the following.
Open: the file.php that cTracker has blocked.
Find:
define('IN_PHPBB', true);
After Add:
define('CT_SECLEVEL', 'LOW');
Edited by Guest, Tue 08 Sep, 2009 05:12: Changed the title a little bit. ;)
Post Re: CBACK CrackerTracker Has Detected A Potential Attack
is a potential security risk
better you read the ctracker debug mode manual
maybe it's not so easy as your way but it's saver
you can download the manual here >> http://www.community.cback.de/viewtopic.php?p=91202#91202
or use this from the attachment
CrackerTracker HowTo - english.zip
Filename: CrackerTracker HowTo - english.zip
Filesize: 46.87 KB
Downloaded: 692 Time(s)
New PlayerSend private message
With the amount of safeguards going into the next release of Icy Phoenix, I'm not exactly sure what role cTracker will play in the overall security picture.
Also, Icy Phoenix code is moving away from a lot of the basic phpBB code, whether that has any relevance or not is to be determined. But I would rather MG provide solutions for cTracker than apply anything that is basically written for Orion.
And as always, he or any other Staff Member is welcome to correct this document as they see fit.
