Re: Is There An Modified Easymod For Phpbbxs?
I have the Arcade Mod on my board and it works fine. I have 203 games installed!
All you have to remember is that when you install it, sometimes the spacing is a little different than what you have to search for.
If you have Dreamweaver use it for your editing. I find that the search feature is really good since sometimes you have to search for multiples lines at one time.
The time now is Sun 12 Apr, 2026 04:37 • All times are UTC + 1 Hour [DST enabled]
