Post Borders/Title Headers Missing From Some Blocks
hello,i have a problem,i have ip 1.2.0.27c,and the borders around the block of new themes (lopalong's themes) they are not seen in my site,what can i do?
thanks
AleeeeSend private message
Post Re: Borders/Title Headers Missing From Some Blocks
Aleeee,
You want to start this all over again here without stating that this has also been thrashed at Icy Themes?
You don't give people very much to work with, do you?
For anyone interested in helping with this, the url will give you some idea of what has already been addressed.
h**p://icythemes.com/ip/crystal-bor...vp281.html#p281
Aleeee wrote:
i have see now your post,if i change the borders and i save it,the settings are not saved,why?
You have either a CMS or Database or file problem - probably still for the wrong version you are currently using.
sorry, you are right
and now?
considering that I have a mixture of ip v15 and ip v27b...
...what can i do???
it's a dangerous problem????
is possible to fix it?
thanks
Readme
ok,thanks!!!
and after this procedure I have the ip 1.2.0.27 with all fix?
cms,db and file?
p.s.
thanks
sure
New PlayerSend private message
i have launch update_to_ip.php, but a lot of options have an error:
20080924170843_screenhunter_2
it's the same?
i continue to procedure?
thanks
Aleeee wrote: [View Post]
it's the same?
thanks
well , you have backup of database from phpmyadmin ,right?
how many errors you mean 30% 50% 70?
i have two backups of phpmyadmin and two backup of mysqldumper that i have do this morning.
the screen that i have posted show the image that i view when i launch update_to_ip.php and i run the update,what can i do?
I I need a way for fix my problem that is I had a mixture of ip v15 and ip v27b db
thanks
thanks
ok few errors is ok , but if you have lot then can be problems...
but as i see in this post u have mixture of different versions IP...
well my opinion is also to do this as novice programmer suggested you
or wait that somebody answer you with realy good mysql knowledge
i have finish the procedure now,but with all themes the options of blocks isn't save
and in the lopalong themes the error is about cms.php:
ould not insert data into blocks table
DEBUG MODE
SQL Error : 1054 Unknown column 'border' in 'field list'
Line : 886
File : cms.php
what can i do?
help me please
thanks
p.s.
now anybody themes are borders
DEBUG MODE
Line : 886
File : cms.php
what can i do?
help me please
thanks
p.s.
do you know to open database in some editor like notepad?
i would love to check your table ip_cms_blocks
but i m not sure if can help
this is my ip_cms_blocks
what can i do?
thanks for help
ipicmsblocks.zip
Filename: ipicmsblocks.zip
Filesize: 3.81 KB
Downloaded: 194 Time(s)
what can i do?
thanks for help
ok , now as i m not expert we can try to reset (i mean to put default) blocks like in new instaled icyphoenix
but u will gona loose all your blocks made by you... (clock,visitor locations ect...)
and made them again if we repair that (you have database so you can resore in this state if we dont repair)
so what is your answer ?
PS. i have to ask you this : did you maybe instaled or tryed to install CMS ADV 1.0.4b for Icy Phoenix 1.2  ?
Limun wrote: [View Post]
what can i do?
thanks for help
you can try please
my answer now is: ehat can i do for view the borderso of blocks correctly?
i I had installed cms adv when i I had only mg_themes i don't know that it work with lopalong's themes
thanks
