Well, I post a pic in order to show the problem.
As you may see, I guess some smilies' width are the troublemakers, so I'd like to know this box pattern (for example if it shows the images on alphabetical order or what) and if it's possible to custom the box in order to show the smilies I choose or at least to fix the table width, or maybe to set the number of smilies which should be shown, 5x7 for example, or any solution you can give me.
Thanks in advance.
