Warning: include_once(./language/lang_/lang_randomquote.php) [function.include-once]: failed to open stream: No such file or directory in /home/.foxie/gearmeister5/portal.thegtsaga.net/main/blocks/blocks_imp_random_quote.php on line 31
Warning: include_once() [function.include]: Failed opening './language/lang_/lang_randomquote.php' for inclusion (include_path='.:/usr/local/php5/lib/php:/usr/local/lib/php') in /home/.foxie/gearmeister5/portal.thegtsaga.net/main/blocks/blocks_imp_random_quote.php on line 31
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
if ( !defined('IN_PHPBB') )
die('Hacking attempt');
Re: Php Error In Blocks_imp_random_quote.php
i would check if u have in all your "lang_ " this file lang_randomquote.php
global $lang, $board_config, $template, $phpbb_root_path, $phpEx;
let us know if help
The time now is Thu 26 Feb, 2026 20:28 • All times are UTC + 1 Hour
