Post Category Creations
Hello
I did not find how to set the Category creations in the forum, I just do not create more than 2 categories, the following message appears:
Fatal error: unlink(./../cache/sql_moderators_a9f113edc3358b5f2456bff4705d7906.php) [<a href='function.unlink'>function.unlink</a>]: No such file or directory in /mnt/104/sda/3/0/www.zonegenerateurs/includes/db/mysql4.php on line 703
Then on the forum that I post a message this message appears on a blank page:
Fatal error: array_multisort() [<a href='function.array-multisort'>function.array-multisort</a>]: Argument #1 is expected to be an array or a sort flag in /mnt/104/sda/3/0/www.zonegenerateurs/includes/functions_categories_hierarchy.php on line 453
It was a week that I return the forum and the doc without finding a solution to these problems. The chmod can not be changed on the host, this does not preclude a forum phpbb to operate above the base. my host free.fr
Thank you very much for your help, good day
Edit : I refer to this post
[*]You have to create a subforum counter in the PHP file which generates subforum listing (if I remember well is includes/functions_category_hierarchy.php), so when you have more than X (depends on your taste...) subforums a new row is created.
[*]You have to modify the template file (if I remember well is templates/YOUR_TEMPLATE/index_box.tpl) inserting a table and a template switch for increasing ROWS and CELLS accordingly.[/list]
do you think the error come from this little manipulation that has not been done?
nenessSend private message
