Post Buttons Gone ?
I have a little problem with the Milky Way Style. I have installed it successfully but the imageset wont go with it. In other terms i cant open a forum topic because the button to open it just isnt there ? Is there a way to fix this ??
Thanks in advanced
Aaron
EfendimSend private message
Post Re: Buttons Gone ?
You are talking about Milky Way on IcyPhoenix or are you using phpBB3?
