Post Adding <script>
I've added textbox with my emff player bbcode, like this.
The problem is with script which on click in codebox selects everything inside.
In the beginning it was working fine, and the suddenly stoped working.
I have added this in veiwtopic_body.tpl, after line "<script>"
function select_text()
var content=eval("document.myform.field");
content.focus();
content.select();
And in bbcode
<form method="post" action="" name="myform" >
<textarea name="field" rows="4" cols="40" onClick="select_text();">Click Inside the text area to select all
  text within this form field </textarea>
</form>
It appears to me like that script isn't loading, could anything be blockin it?
In fresh instalation works fine.
I just found out that problem begins when two posts are posted, and both call that javascript.
So in viewtopic_body.tpl is not good place to put it.
So where is best place to put that javascript?
strujaSend private message
Post Re: Adding <script>
struja wrote: [View Post]
maybe in templatescommonjs
Nope, it didn't work.
The problem is that you need to assign an ID to the form and then pass it to the JS so you can have multiple form and you will be able to select multiple text in the same page.
Try to check how QuickQuote works...
I've tried with this
<script type=”text/javascript”>
function SelectAll(id)
document.getElementById(id).focus();
document.getElementById(id).select();
</script>
<textarea rows="3" id="HERE" onClick="SelectAll('HERE');" style="width:200px" >This text you can select all by clicking here </textarea>
But problem, at least for me is. How to assign unique value there.
I tried just putting ' . $post_id . ' , nothing happened.
If you don't have an ID, then you need to create a random ID using some random function and then send it to template.
Check also bbcode.php what has been done for code select and download.
So I added this code before $html to generate that random id.
$box_id = substr(md5($content . mt_rand()), 0, 8);
it is working for now.
Thanks MG, for your guidance. It was much better for me than just a solution.
Great!
