Post Fix Calendar Width
Hi Guys!
I'm looking for some help, (wich is obvious since i'm posting here   ), i'm having a problem with the calendar events titles.
When the title exceed the day size, the cell auto increments its size, instead of truncate the text (i'm from Brazil so i don't know if this is the right word). In other words, i want that my calendar don't exceed the page limits and i want that every day have the same width, if the event title exceed these limits, i want that the line breaks and continues below...i really don't know if you'll understand me...
By the way, i'm sending an imagem of my calendar...
Thanx in advance guys!
Filesize: 99.76 KB
Viewed: 160 Time(s)
rafaelySend private message
Post Re: Fix Calendar Width
I hope you are using IP .27
You can change the title lenght in ACP
Take a look at the pic.
 calendar
The seconde is you can change the look of the date
Maybe to "Dez." instead of Dezember
But I think the first solution will be the best instead of fix only the calendar with.
Yeah man!
I realize that i'm not able to break lines in the calendar 'cause i could have more than one event per day.
I already made the changes you suggested but is not what i wanted in the first place but since IP has these overview_event_box i'm satisfied with the result.
Thanx anyway man!!!
Hm, OK, maybe some other User can help you.
You can choose a template with fix width or you can play a little bit with calendar_box.tpl
