Smoke Pearl => Board Index ? Search => Homepage
Goto page 1, 2, 3  Next
Subject: Smoke Pearl => Board Index ? Search => Homepage
I've a Problem with Smoke Pearl-Style:
First: sorry for my well spoken English :mrgreen:
If i go to Search => next Step: Board Index » Search
I click to Search => i come to the Homepage like www.homepage/#
Any ideas?
(I've installed a Portal and SEO-Mode, but i don't know the first Time of this Error :oops: ).
THX!
Forum: http://www.ftf-unlimited.net/index.php
Subject: Re: Smoke Pearl => Board Index » Search => Homepage
i m not sure if i understand so:
do you mean If i go to Search => next Step: Board Info » Search
because i get this
search1
and results
search2
and your forum is in german so its bit difficul to understand to me
Hi Limun :mrblue:
Nice to see U
i switchted to english for better unterstanding:
I goto search => Line "Board Index >> Search"
If i click on "Board Index >> Search" i come to the Homepage/#... :(
It's crazy, i can't say if the error was bevor installation Seo & Portal.
I don't know how to look for this :oops:
THX!
Filesize: 47.32 KB
Viewed: 207 Time(s)
Subject: Re: Cant Disable Nav Block From Homepage And C...
i m still on german and not blue_peral
can u provide test account
You can register any Time...but you can see it as guest...
EDIT: sorry, my User's prefer subsilver2, smoke pearl is an option.
I switched the guest's to smoke pearl :wink:
EDIT 2:
I switched off the SEO-MOD, the Result is the same.
I think it was before i've installed SEO-Mod / Portal :(
1 . did you uploated all files for portal
2 . does it hapening only on smoke_peral because i dont see in subsilver2 navigation "search" when you are in search.php like on smoke_peral
3 . did u added all files for subsilver2 and codes
4 . try to replace search.php from your root (backup your original before)
than we continue
1 . did you uploated all files for portal => YES, it's the same in my Test-Forum (i've installed before)
2 . does it hapening only on smoke_peral because i dont see in subsilver2 navigation "search" when you are in search.php like on smoke_peral => YES. The other Style doesn't provide this links
3 . did u added all files for subsilver2 and codes => Yes. I've checked it for 3 times
=> i'll check it in my Test-Forum and report the results.
I saw the same Problem occurs with Homepage/members :cry:
THX for your Support !
EDIT. I've replaced the original smoke pearl-Style in my Test-Forum - the Result is the same... :(
I try to disable the Portal...
Charlie_M wrote: [View Post]
do not disable man
1. subsilver2 is ok...
2. i suggest you to unninstal smoke_pearl , and install it again (do not replace ... )
BTW did you added codes for smoke_pearl from instructions somewhere in this forum
3. from where did you get this smoke_peral? i cant find it here :shock:
Limun wrote:
do not disable man
I've disabled the Portal and SEO-Mode and installed original File's of Smoke Pearl (after deinstalling).
Yes, i've installed the necessary Code's eq. to Subsilver2 (SEO and Portal)
Smoke Pearl => i've got the Style from Icy Phoenix - ColorizeIt
EDIT: in prosilver / subsilver2 there's no link like "search" or "members" (eq. Forum>> Search - Forum >> Members).
I think it would be ok for me to disable the links like subsilver2.
are we on same link ?
because i still see portal (which you disabled as you say which you disabled) and i see Subsilver2
link where i m is http://www.ftf-unlimited.net/
You've got a PN :oops:
sorry , i was so tired yesterday...
did you solved problem now ?
Hi Limun,
no, ididn't resolve the problem...
Links like "Forum>>FAQ" works...but not Search and Member.
I reconised that this functions are not available in the standard-styles, proberly the wouldn't rewritten correct by SEO-Mode.
I think the best way is to disable the functions in pearl...must search for...my Coding-Know-how ist as well as my english :-))
It is not a bug, it is the way the template is designed.
Unfortunately not all links are sent to template so I couldn't add the correct URL to all breadcrumbs.
but i can delete the addinional link "Search" from "forum>>Search" eq. Member?
Or its possible to change to a URL?
the error ist:
- Forum/# instead Forum/search.php
- Forum/# instead Forum/members.php
Page 1 of 3
Generation Time: 0.1115s (PHP: 20% SQL: 80%)
