Changing Banner
Subject: Changing Banner
I have read nearly all topics about this and nothing happened. Same old banner stayed there. How do I change the banner on the mars attack theme to
http://www.icyphoenix.com/customicy...=1&tcc4=664477& ??
Subject: Re: Changing Banner
Hello Rocko,
Please post in the correct area.
Moving to Templates And Styles.
Have you tried:
How To Change Banner...
Header Banner Not Changing [SOLVED]
Don't forget to clear your cache after changing the banner. Sometimes it will show up without clearing the cache, but it doesn't hurt to clear it just in case.
I did all that. I checked those topics but the theme logo will not change.
Did you take the image you created in CustomIcy and rename it to: sitelogo_small.png and upload it to:
ip_root/templates/mg_themes/images/dark_blue/
I do not have that folder...
Did you download the Mars Attack Template?
http://www.icyphoenix.com/dload.php?action=category&cat_id=14
Upload it to your Icy Phoenix root and try my last post again.
I always thought the styles went into the styles folder :? I did upload and It still doesn't change.
Would you mind posting a link to the site you have IP installed on?
Generation Time: 0.0902s (PHP: 19% SQL: 81%)
