SOLVED :Problems Installing Fk_nuke
hy there
i´ve got a huge problem installing fk_nuke.
i´ve copied al files into templates next to MG but the problem is that after install of nuke theme i get an error message from the includes def_themes on line 2.
and the program just want do anything.
it just blocks and i get a blank screen with error message
can somebody help me?
____________ Out of Order
Re: Problems Installing Fk_nuke
Parse error: syntax error, unexpected '<' in /mnt/web7/20/54/51902354/htdocs/spydie/ip/includes/def_themes.php on line 2
and yes the file was charmoded
problem is that there is no way that i could change anything back to normal cause that error message shows up on every screen and i couldnd get back to normal. it allows no more changes not nothing
can you post your def_themes.php here in spoiler please
BTW...is it your def_themes.php chmoded on 666?
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
if ( !defined('IN_PHPBB') )
die('Hacking attempt');
exit;
<?php
* def_themes_def.php
* begin : 12/11/2003
* copyright : Ptirhiik
* email :
* version : 1.0.0 - 12/11/2003
* last update : 2008-12-06 13:39:53 (GMT) by spydie *
exit;
absolutly no changes at all.
but thanks anyway
maybee i´m just to new to try to change anything at all.
everytime i´m trying anything goes wrong
and that after doing exactly what i should .
but thanks anyway
can you post link to your site...
it cant be if you copyed that isnt work
BTW affter you copyed ..try to empty cache
tryed everything.
the program shows me the same all the time.
no chance to do anything.
i click on a other option and nothing.
all the time white screen and error message
always same error...?
BTW please post link to your site or PM me link
);<!-- template ./..//includes/cache_tpls/def_themes_def.tpl end -->
what i just noticed uploading afrodite theme is
that fk_nuke has´nt got any pafiedb files. isn´t that necesari ?
could that be the problem ?
i just tested fk_nuke , and its workong
from where did you downloated fk_nuke?
The time now is Sat 22 Nov, 2025 12:43 • All times are UTC + 1 Hour
