Page 1 of 3
Goto page 1, 2, 3  Next
Post [Solved] BlogMod For XS2 problem
hi,
I try to install TheBlogMod on XS...but doen't work when I post in blog...
see a test: http://www.ilsitodellagiungla.it/forum_test/weblog.php?w=1
I see that BlogMod in Difus's site is ok...any suggestion??
greetings
hpl
hplSend private messageVisit poster's website
Post Re: BlogMod For XS2
never had this problem
maybe you are missing something
*VOLVO CLUB*
hpl wrote: [View Post]
hi,
greetings
hpl
please send the link of the original mod,
if you have 1 problem,
please put the link for original mod, and if have erros, please put pictues.
My New php is the IcyPhoenix
Kravianos PT
nickjackSend private messageSend e-mail to userVisit poster's website
hi,
greetings
hpl
try
download my release, extract includes/bbcode.php
replace bbcode.php [overwrite] with yours
if nothing I'll prepare for you weblog install.txt
then you can compare with your's installation
*VOLVO CLUB*
difus wrote: [View Post]
try
where is your release ?
Kravianos PT
at the bottom
*VOLVO CLUB*
at the bottom
sorry
where is the bottom????
Kravianos PT
hi,
greetings
hpl
try
GREAT!!! The problem is BBCode, is true.. Now BlogMod is OK
THANKS!!!
nickjack wrote: [View Post]
at the bottom
sorry
at the bottom of my post you can see phpBBXS_058a_difus2.9[en]
*VOLVO CLUB*
another bug: the blog doen't work if there is in post this simbol: '
Could not insert entry into database
DEBUG MODE
SQL Error : 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'è', 'a8a53d84df', -1, -1, '', 1161790918, 1, 1, 0, 0, 0, 2, 2, '')' at line 2
INSERT INTO phpbb_weblog_entries (entry_id, weblog_id, entry_access, entry_subject, entry_text, bbcode_uid, entry_mood, entry_currently, currently_text, entry_time, enable_bbcode, enable_smilies, enable_html, memorable, no_replies, entry_last_post_userid, entry_poster_id, category) VALUES (5, 1, 0, 'test', 'all'è', 'a8a53d84df', -1, -1, '', 1161790918, 1, 1, 0, 0, 0, 2, 2, '')
Line : 598
File : /var/www/vhosts/ilsitodellagiungla.it/httpdocs/forum_test/weblog_posting.php
is it in my site too?
can you post ' on your fourum?
can you insert the picture using img tags ?
*VOLVO CLUB*
in your site is ok (see my test with ' ), the bbcode is all ok in your and my site (img tags work)
--> http://www.ilsitodellagiungla.it/forum_test/weblog.php?w=1
but in my site I can't use '
in site or in weblog or both ?
what is your mysql charset code?
mine Unicode (utf8) ci
*VOLVO CLUB*
charset is utf8,
in forum I can use ' , but in webblog I can't....
where do you get this mod?
can I take alook?
*VOLVO CLUB*
Post new topic  This topic is locked: you cannot edit posts or make replies.  Page 1 of 3
