FAP CUSTOMIZATION - Link To Personal Sub Cat In Lang File
Subject: FAP CUSTOMIZATION - Link To Personal Sub Cat In Lang File
Hi
I would like to place a link in a lang file that goes to members personal sub cat..
I manages to get a link to work to goto members personal album I used...
<a href="' . append_sid('album.' . $phpEx . '?user_id=' . $userdata['user_id']) . '">
this works fine..
all my membes have one sub cat and I would also like to point a link to there is this possible I have tried
('album_cat.' . $phpEx . '?cat_id=' . $cat_id . 'user_id=' . $userdata['user_id'])
but it does not work...
I would like the link to show you the members upload avatar page which is this link profile.php?mode=editprofile&cpl_mode=avatar
or is it possible to just add a link in the tpl file and which files do I need to edit... sorry if this is not in the right forum...
Subject: Re: Link To Personal Sub Cat In Lang File
Not sure I understand exactly what you are asking :? :?:
Your members only have 1 sub-cat in their personal gallery and you want a link to that sub-cat .
Are you saying that you want that link to show on the user's Avatar Control Panel page :?:
Moved to proper forum - FAP General Discussions And Customizations
Artie wrote: [View Post]
yes exactly if that is possible... thanks for reading
There are 2 different tpl files for the Avatar CP ... I assume you want the link in the menu on the left side of the page.
You can copy code from profile_main.php to cpl_menu.php and that should give you your sub_cat_id.
COPY
$sql = "SELECT * FROM " . ALBUM_CAT_TABLE . "
WHERE cat_user_id = " . $userdata['user_id'];
if( !($result = $db->sql_query($sql)) )
message_die(GENERAL_ERROR, 'Could not query album information', '', __LINE__, __FILE__, $sql);
while($row = $db->sql_fetchrow($result))
$sub_cat_id = ($row['cat_parent'] > 0) ? $row['cat_id'] : '';
$db->sql_freeresult($result);
if (!empty($sub_cat_id))
$u_personal_gallery = append_sid('album_cat.' . $phpEx . '?cat_id=' . $sub_cat_id .'&user_id=' . $userdata['user_id']);
else
$u_personal_gallery = append_sid('album.' . $phpEx . '?user_id=' . $userdata['user_id']);
ADD TO cpl_menu.php (you can add just before the template variables are assigned)
Assign and add some template variables and it should work ..... keep in mind that if a user has more than 1 sub_cat, then the link will take you to the last sub_cat that was created.
excellant thank you
what if I would like it just by the upload avatar area which php file would I need .. and what code do I place in the tpl file...
thanks again
It would be the same php file, but the tpl would be profile_add_body.tpl
Put your link in the area between
<!-- BEGIN switch_cpl_avatar -->
AND
<!-- END switch_cpl_avatar -->
sorry really confused now... I cannot find cpl_menu.php in any of the files (using latest version)
and still not sure what to place in tpl file...
sorry for being a pain..
I'm sorry that php file is no longer used... I need to update to the current version of IP ..... :censored:
I'll have to get back to you on this after I upgrade.(I've put it off long enough :roll: )
But the new php file would be usercp_register.php if you wish to try yourself.
no worries I thought it was either you or me... LOL
I had a go using usercp_register.php
but I cannot get the right code for the tpl file...
:mrgreen: :mrgreen:
OK, I'm now using ver 1.2.0.27 0007
You almost need to be specific where you want the link on the page, because it does make a difference where you need to place the code.
The following code should allow you to place it as shown in the attach pic below.
OPEN profile_add_body.tpl
<td class="row-header" colspan="2"><span>{L_AVATAR_PANEL}</span></td>
AFTER ADD
<td colspan="2"><span><a href="{U_USER_SUBCAT}">{L_USER_SUBCAT}</a></span></td>
OPEN includesusercp_register.php
$template->assign_block_vars('switch_cpl_avatar', array() );
BEFORE ADD
else
'L_PROFILE' => $lang['Avatar_panel']));
BEFORE ADD
'U_USER_SUBCAT' => $u_personal_gallery,
'L_USER_SUBCAT' => "HERE IS YOUR SUB_CAT LINK",
MODIFY TO SUIT YOUR NEEDS
usercp
Hi Artie
Thanks for the help with this... I have followed your guide above exactly and checked it 3 times... but for some reasons the link just sends you to the members 1st personal gallery and not the sub_cat...
I have checked to see if the member has a sub cat which they do... but for some reason it will not pick it up..
any ideas..
:mrgreen: :mrgreen:
Works fine for me :roll:
You must inserted something in the wrong place... hard to say without seeing your modded files/code.
Hi
Well after checking and rechecking :roll:
I replace this part
with this
$sql = "SELECT * FROM " . ALBUM_TABLE . " AS p, " . ALBUM_CAT_TABLE . " AS c
WHERE c.cat_user_id = " . $userdata['user_id'] . "
AND p.pic_cat_id = c.cat_id
AND p.pic_approval = 1
ORDER BY pic_time DESC";
message_die(GENERAL_ERROR, 'Could not query recent pics information', '', __LINE__, __FILE__, $sql);
and all works good...
thanks though I do not know why mine is different to yours :roll:
DWho wrote: [View Post]
Me either .... glad you made it work for you.
Thanks again for the help...
:mrgreen: :mrgreen:
Generation Time: 0.1689s (PHP: 13% SQL: 87%)
