My time/date is 05/01/2009 - 15.53 but if i send a message in the chat box it comes up as this 2009/01/05 - 08.53.00 ???
A 7 hour time difference, can this be changed?
TIA
Hunter
try to go in your profile and set your time zone ..i think it will help
Re: Chat Box Time/Date
This has been an ongoing problem since I started using Icy Phoenix. I never found a solution to setting the time correctly in the Ajax Shoutbox, so I switched to the old shoutbox instead.
Thanks for your reply. It a shame we cant get it to work. Today i looked at mysql and took the time stamp from a test post and converted it and it was the correct time and date so i guess its a break down of code some where. I have been looking at all the ajax files but still no joy, if i do ever fix it i will post back what i did.
The time now is Sat 31 Jan, 2026 12:38 • All times are UTC + 1 Hour
