Hi, just wonder if here are someone that can help me with one thing.
I have put up this CMS and i am from Sweden. Have also translate this to my language.
The problem i have is that in my language there are some more letters than here.
For example the memberlist there are Letters from A - Z.
So now i wonder what shall i do if i whant more Letters here. We have 3 more in my language
It is from A - Z and after that last one (Z) there are also Å Ä Ö
Someone, please
Jogge
Help With Letters
Subject: Re: Help With Letters
I think that those usernames are not valid. Try registering a username with those characters on your board.
For Usernames you can du this: http://www.icyphoenix.com/viewtopic.php?t=1276
I have the same problem with ä,ö,ß etc.
Or do you mean the letters for sorting?
Thanks for the answer The Steffen and Novice programmer.
That i whant is very in the code can i put in the missing Å Ä Ö, must go becuse
i have done that in a other forum long long time ago.......and i can´t remember how. :?:
thanks
Jogge
thanks
Jogge
Generation Time: 2.2593s (PHP: 2% SQL: 98%)
