Re: Just Found A Bug In This Forum
yep
its because of [img align=left] in same post with code , quote or php bbcode
if you remove [img align=left] than its ok
Re: Image Align Bug [Beta 2]
The align property with images makes text and floating objects surround the image... unfortunately there is no easy way to make things working different.
In those cases you have to insert extra line breaks to fix the final output.
The time now is Thu 09 Oct, 2025 23:03 • All times are UTC + 1 Hour [DST enabled]
