Post New Vars In lang_bbcb_mg.php
I just wanted to inform all translators that I have finally removed the js file in lang folder...
We now have a single JS file which import lang vars from a standard lang file which is lang_bbcb_mg.php.
I have recoded this file in the RC so you will need to translate it again... and please pay attention at the special code at the bottom of this file since it must remain as is:
// Please do not remove this!!!
foreach ($js_lang as $k => $v)
    $lang[$k] = $v;
$javascript_lang_vars = '';
    $javascript_lang_vars .= 'var ' . $k . ' = \'' . str_replace("'", "\'", $v) . '\';' . "\n";
$lang['JAVASCRIPT_LANG_VARS'] = $javascript_lang_vars;
unset($js_lang);
// JavaScript Text - END
I strongly recommend all translator to carefully review this file and update the packages... or you could have errors in all posting forms in Icy Phoenix.
Post Re: New Vars In lang_bbcb_mg.php
Thanks for the information MG
Post Re: New Vars In Lang_bbcb_mg.php
Thanks for reporting it to us!
Please test the BBCode Box after having translated that file... just to make sure that everything is working properly.
Post Hi,
Thank you for reporting this. Just to make sure that everything is working properly.
Gadner2Send private message
I want to know ... I have this file on my lang_french folder: Did I have to translate it ?
Yes, but not this part of the file
    $lang[$k] = $v;
unset($js_lang);
... I don't understand.
*EDIT: This file have 100 lines, but there is the same var in lang_bbcb_mg.php !
so, I don't understand, thanks ^^'
Hm, now I understand what you mean...
For german we have translated both files.
bbcb_mg.zip
Filename: bbcb_mg.zip
Filesize: 12.97 KB
Downloaded: 461 Time(s)
Ok thx I will translate once and do put the result in the js file ...
