Post Solved: Moving Into A Sub Folder
I had my XS in the root directory and I needed to move it into a sub folder but after the move the photo gallery and the download section don't work.
The photo gallery shws the red x in it and the download section tell me when I go to make a download that I can not download from another website, in which case I am not I am trying to download right from that website.
I am sure somewhere the file paths have not changed but where would I have to do that? Everything else is working fine. And everything was working fine before I made the move. I am using the most recent version of XS.
GarySend private message
Post Re: Moving Into A Sub Folder
It should be enough changing your path in CONFIG section in ACP.
Can you check where the links are pointing?
Also... be sure to empty all the caches: STYLES, ALBUM, PRECOMPILED POSTS.
If you can't get into ACP
go to SQL find script_path, change it
clear cache folder
that's all
EXAMPLE
Filesize: 9.59 KB
Viewed: 12653 Time(s)
*VOLVO CLUB*
Post Solved Moving Into A Sub Folder
Thanks for the information. It was a setting in the ACP was wrong I change it and all is working perfect.
This is what I did for anyone else who may run into this it is.
In the ACP I went to Setting>>Server & Cookies and in the form for Domain Name I changed it from www.myname.com to myname.com and that was it.
Thanks again.
Great!
