SOLVED Can I Change The Style With A Link?
Subject: Can I Change The Style With A Link?
Hello,
Can I change the style with a link such it do in other system forums?
Example:
www.portalpez.com/index.php?style=1 or some like that...
If i can, how is the correct parameters to change the style with a link?
Thank you very much.
Subject: Re: Can I Change The Style With A Link?
see this
http://www.icyphoenix.com/viewtopic.php?f=6&t=5291
i made it changing style on click...maybe you can get out something :oops:
Hello Limun,
How are you? Excuse the delay in answering you and thanks you.
Your templates are very good... and it is very interesting the module to change the templates, but It meaning for me to change all in my forum. I hope MG integrate this in the future.
Thanks you very much.
If you´ve got different styles installed. you´ve got the option to allow users to change style in the left menu.
theres an option in ACP to switch style change on.
That is in ACP-IcyPhoenix-Icyphoenix enable style change
on the left site in index and forum apears then a small style change window there users can select the style.
Thanks you, but i need that the change be with a link... :wink:
portalpez wrote: [View Post]
see this
http://www.icyphoenix.com/forum.php?s=1
http://www.icyphoenix.com/forum.php?s=2
http://www.icyphoenix.com/forum.php?s=3
http://www.icyphoenix.com/forum.php?s=4
http://www.icyphoenix.com/forum.php?s=13
so
?s=xx
:wink:
Thanks you Limun!!!!
:wink:
Generation Time: 0.0868s (PHP: 20% SQL: 80%)
