Post RC1 Buttons Issue [UPDATED]
i have found a little issue with the pearl theme buttons...
all the buttons are in gif format... but the board is using png format buttons... as result, the buttons doesn't appear cause the buttons doesn't exist...
this is only a little inconvenient... i will try to solve it now, and i will update the post with the correct buttons...
greetz!!!
EDIT: Here you are the png format buttons... this will solve the problem when the buttons dont appear...
lang_spanish_Black_pearl.rar
Description: Black Pearl PNG buttons
Filename: lang_spanish_Black_pearl.rar
Filesize: 228.66 KB
Downloaded: 116 Time(s)
lang_spanish_Blue_Pearl.rar
Description: Blue Pearl PNG buttons
Filename: lang_spanish_Blue_Pearl.rar
Filesize: 230.07 KB
Downloaded: 112 Time(s)
paramine-gxSend private messageVisit poster's website
Post Re: RC1 Buttons Issue [UPDATED]
Thanks paramine-gx for your hint and converting gif in png.
MG told me, that all buttons for next IcyPhoenix 1.3 should be gif because its works better with Internet Explorer.
Let see what MG want to say
Anyway, I have the psd and it is only a simple click to save it as png
TheSteffen wrote: [View Post]
  ok, i didn't know that... i think that gif works better too, but i dont know how to change this in the icy files xDDD
anyway, this can solve the trouble while the next realease is ready n_n
You can switch the button.ext in the theme.cfg that you are using. (Not the theme_info.cfg).
$images_extension = in_array($color, $png_colors) ? 'png' : 'gif';
$buttons_extension = in_array($color, $png_buttons_colors) ? 'png' : 'gif';
Just swap the .png and .gif.
