Hello There,
we are moving our phpbb2.0-Board to a new server. (Yes, we know its a bad idea not to use phpbb3, but we have our reasons!).
Now I'm stuck in the case, that the multiupload with nuffload isn't working anymore. It's just uploading the first picture and no other.
Whats going on?
Have a nice day,
Stefan
FAP SUPPORT - Multi Upload Doesn't Work After Moving The Album
Subject: Re: Multi Upload Doesn't Work After Moving The Album
Sorry, but I can't help with Nuffload.
It is coded in Perl and there are some basics requirements for your server to support it.
Try to dig in old support topics... or here:
http://www.mightygorgon.com/forum.php?c=8
Thank you. :)
We are using 1.4.1 of the FAP on a PHP5-Server.
Nuffload is enabled due to the multiuploadsupport, but the perluploader is disabled.
I will have a look on the old supportforums, but maybe you can give me a hint to chase after?
stefan
stefan
Generation Time: 0.1607s (PHP: 10% SQL: 90%)
