SOLVED: Need Help With Video In Header
Subject: SOLVED: Need Help With Video In Header
Hi all.
Got a small problem.
I´ve got this code in my header.
to show a flash video on right site of banner.
now ive got this problem.
i got this.
dibujo_1
and i want this
dibujo2_1241300596_466434
how can i double the size of video, not of player
Subject: Re: Need Help With Video In Header
hi try changing the width in the embed code... width="320" you need to do this twice...
do you have a link.....?
:mrgreen: :mrgreen:
u need to edit flash in some flash editor and resize it to your dimensions
if u dont do that u will always have that white space nomather how you change size in code
so:
if you want video 500x200 u need to resize it with some editor for video
i told you this in PM
DWho wrote: [View Post]
:mrgreen: :mrgreen:
theres no link cause at the moment i´m testing that localy.
Limun:
I´ve been trying with a lot of converters and Programs changing size and everything and no way.
have you got a copy of the video.. then I can see if I can get it the way you want...
PM if necessary
:mrgreen: :mrgreen:
Inactive User
To remove the white bits I always thought one added the wmode twice ?
h**p://***.google.com.au/search?hl=...ash+background+
Ok thanks everybody.
Specialy to Limun. got it sorted with the link you posted.
My problem was that i did´nt get the right converter. everything i tried was crap.
Now i got it with Moyea Flash Video MX Std
Generation Time: 0.1799s (PHP: 10% SQL: 90%)
