Re: Need Help Plz
please rename your subject "Need Help Plz" to something about your problem
now:
tell us this :
which version of Icyphoenix you have
what style you are trying to install (from where did you get style you try to install) ?
Re: Need Help Plz
are you sure that u downloated black_pearl for RC ?
i see that http://www.icyphoenix.com/styles/ doesnt work now , so where did u get black pearl ?
sorry for so many questions ... but if you downloated black pearl for 27c version it will not work with RC
thanks for ur help
i have last question?
i need to make banner 890*232 in the top of my forum but it's repeat how can i stop that u can see what i mean
www.mdk-guild.co.cc
why don´t you just replace sitelogo_small withg your banner image
that is a good idea
The time now is Fri 10 Oct, 2025 03:18 • All times are UTC + 1 Hour [DST enabled]
