Hi Guys,
I have a string eg - 21/07 which represents a date, i need to upload it to a database in 21/07/09 format, how can i do this with PHP, i know how to update the database, but how do i convert string ( eg 21/07) to a date format ( dd/mm/yy )
regards
How Do You Convert A String To Date
Subject: Re: How Do You Convert A String To Date
hey andy,
if you want to have the date for IcyPhoenix... its better to note convert the string in a date... its better to use the UNIX timestamp... then you can call the timestamp with the create_date_ip() function from Icy...
this might be helpfull for you http://www.php.net/manual/en/function.strtotime.php
Better than thousands words:
http://it2.php.net/manual/en/function.date.php
http://it2.php.net/manual/en/function.gmdate.php
http://it2.php.net/manual/en/function.mktime.php
http://it2.php.net/manual/en/function.gmmktime.php
Thanks guys, got that sorted and now having problems with something else to worry about LOL
Ahhh the joys of writing code !!
Generation Time: 0.1905s (PHP: 10% SQL: 90%)
