Post Again I Got A Problem Installing A MOD And Other Big Problem :S
I have other problem:
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3838: Cannot modify header information - headers already sent by (output started at /language/es/common.php:1)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3840: Cannot modify header information - headers already sent by (output started at /language/es/common.php:1)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3841: Cannot modify header information - headers already sent by (output started at /language/es/common.php:1)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3842: Cannot modify header information - headers already sent by (output started at /language/es/common.php:1)
And in the ACP:
[phpBB Debug] PHP Notice: in file /adm/index.php on line 152: Cannot modify header information - headers already sent by (output started at /language/es/common.php:1)
[phpBB Debug] PHP Notice: in file /adm/index.php on line 154: Cannot modify header information - headers already sent by (output started at /language/es/common.php:1)
[phpBB Debug] PHP Notice: in file /adm/index.php on line 155: Cannot modify header information - headers already sent by (output started at /language/es/common.php:1)
[phpBB Debug] PHP Notice: in file /adm/index.php on line 156: Cannot modify header information - headers already sent by (output started at /language/es/common.php:1)
This happens when I try to install the MOD level bar 0.0.1b for PHPBB3, probably I failed at the installation but I don't know what's the error, how can I fix it?
I'll attach the install.xml so you see what are the changes of this installation, thank you.
EDIT: I found an error, an important error in the forums. Go to http://fifagaming.x10hosting.com/index.php and try to make a new topic or join a post...
The page does not load and the screen is white when I click in 'Nuevo Tema' ('New Topic') or when I want to see a topic :S
How can I fix that?
These links don't work:
http://fifagaming.x10hosting.com/viewtopic.php?f=2&t=1
http://fifagaming.x10hosting.com/posting.php?mode=post&f=2
install.rar
Filename: install.rar
Filesize: 4.28 KB
Downloaded: 238 Time(s)
BlancoLandaSend private message
Post Re: Again I Got A Problem Installing A MOD And Other Big Problem :S
Sorry but I have no time for testing MODS on phpBB 3. I don't know if someone else could help with this.
Did you already try to contact MOD author?
No, I will try to contact him.
Do you know a solution for the second issue?
I guess the problem is linked to your hosting.
