Hi all,
I have this unknown pink image located right under my big_buttons.png,
it is only seen in Internet Explorer,
In Firefox it is fine and perfect...
I have searched everywhere to find this image or color to modify or eliminate
so it will look perfect like it should as seen in Firefox.
I am using apple style 1.3.053.
please help me to find this image, thanks.
Filesize: 48.25 KB
Viewed: 168 Time(s)
grafnapSend private message
Post Re: Help To Eliminate Pink Image (style Apple) Under Big_buttons.png
Can you provide a link to check live?
yes sure,
- Link to Site I am Working On -
looks like you need an css fix
there should be some code moved around to fix that.
thing is, i don´t remember where that was
Edit.
you´ve got to change backround color
here :rgb(238, 221, 238)
#EEDDEE
td.forum-buttons (background-color) selected by .forum-buttons in style_apple.css (line 119)
that is this horrible pink.
change it to blue or whatever the backround you want is
thank you very very much spydie, I just eliminated the #EEDDEE and it fixed up perfectly,
thanx again.
Post Re: [SOLVED] Help To Eliminate Pink Image (style Apple) Under Big_buttons.png
glad you solved your problem.
One tip:
If you work on a theme try to use ColorZilla addon for FireFox
That helps a lot to find all color codes in page
