zsolti10
 Language Problem
Hello!
I "convert" a part of 1.2.0.27c language file compatible with 1.3.0.53, but my site display this:
Parse error: syntax error, unexpected ';', expecting ')' in /nfs/x0201/m/mu/muonlinehun/wwwroot/language/lang_hungarian/lang_main.php on line 86
#1 Sun 26 Jul, 2009 20:18 |
spydie
 Re: Language Problem
you should take the English lang file from 1.3.0.53
and just translate line by line.
take your 1.2.0.27 file to compare but don´t use any var of it
It´s enough if you forget to close an simple ( ' ) and everything goes in the sh...er
____________ Out of Order
#2 Sun 26 Jul, 2009 20:36 |
Danielc
It seems to be a problem with the line 86 of the file. Is the syntax well? Are you sure that the string ends with '; ?
#3 Sun 26 Jul, 2009 20:38 |
novice programmer
Hey, post the php string on here (just the var that gives the problem)
OT: So we will get on a rocket on this ticket!  (keyboard is not working properly  )
#4 Sun 26 Jul, 2009 21:03 |
spydie
 To much coke spilled over it or what ??
#5 Sun 26 Jul, 2009 21:05 |
novice programmer
It must be that the holidays are not so good for computers as for humans. I had been at Burdeaux, on France. BTW, we have made 2 offtopics from serious threads on just a couple of hours!
Could be the wet air of that zone  ?
Perhaps it is time for another offtopic thread: Where have you been or will go for holidays this year?
#6 Mon 27 Jul, 2009 00:28 |
zsolti10
The problem is solved ( very big thanks for you), one ' was missing,but now it writes:
Parse error: syntax error, unexpected T_CONSTANT_ENCAPSED_STRING, expecting ')' in /nfs/x0201/m/mu/muonlinehun/wwwroot/language/lang_hungarian/lang_main.php on line 463
lang_main.php line 460-68:
'Stored' => 'Az üzenet sikeresen elküldve.',
'Deleted' => 'Az üzenet sikeresen törölve.',
'Poll_delete' => 'Szavazás sikeresen törölve.',
'Vote_cast' => 'A szavazatod sikeresen elküldve.',
'Topic_reply_notification' => 'Téma válasz értesítés',
'Emoticons' => 'Emotikonok',
'More_emoticons' => 'Összes emotikon megtekintése',
#7 Fri 31 Jul, 2009 14:16 |
Limun
Location: ![[Censor] (Croatia) croatia.png](images/flags/croatia.png) [Censor]
Parse error: syntax error, unexpected T_CONSTANT_ENCAPSED_STRING, expecting ')' in /nfs/x0201/m/mu/muonlinehun/wwwroot/language/lang_hungarian/lang_main.php on line 483
lang_main.php line 483-492
'Login_check_pm' => 'Lépj be a privát üzeneteid megtekintéséhez',
'New_pms' => ' %d új privát üzeneted van', // You have 2 new messages
'New_pm' => ' %d új privát üzeneted van', // You have 1 new message
'No_new_pm' => 'Nincs új privát üzeneted',
'Unread_pms' => '%d olvasatlan privát üzeneted van',
'Unread_pm' => '%d olvasatlan privát üzeneted van',
'No_unread_pm' => 'Nincs olvasatlan privát üzeneted',
'You_new_pm' => 'A new private message is waiting for you in your Inbox',
'You_new_pms' => 'New private messages are waiting for you in your Inbox',
'You_no_new_pm' => 'No new private messages are waiting for you',
i tested this and its ok ,so probably problem is in some other thing
can you post whole hungarian lang_main.php here in spoiler or in attachment please
#8 Fri 31 Jul, 2009 14:43 |
zsolti10
I don't know how, but i solved it
But here is the file
| Description: |
 Download |
| Filename: |
lang_main.zip |
| Filesize: |
32.93 KB |
| Downloaded: |
170 Time(s) |
#9 Fri 31 Jul, 2009 14:56 |
Limun
when i instaled your lang file i got blank page
note that is one strange thing in first line in your file
it didnt show up in notepad
see
so replace
with
#10 Fri 31 Jul, 2009 15:06 |
zsolti10
And what program can remove that?
#11 Fri 31 Jul, 2009 15:17 |
Limun
Win Merge or total commander
strange..
it appaer only in total commander
if i dont remove that  i cant open IP
maybe problem is in my PC
anyway here its your file without this
| Description: |
 Download |
| Filename: |
lang_main.rar |
| Filesize: |
31.49 KB |
| Downloaded: |
155 Time(s) |
#12 Fri 31 Jul, 2009 15:30 |
zsolti10
Thank you for your help
#13 Fri 31 Jul, 2009 15:34 |
| Link this topic |
| URL |
| BBCode |
| HTML |
