Change Columns In News Categories
Subject: Change Columns In News Categories
Hello!
I'm currently editing the news_block.tpl file and have this code:
<!-- BEGIN newsrow -->
<!-- BEGIN newscol -->
<td width="25%" class="row1 row-center"><span class="genmed"><a href="{INDEX_FILE}?{PORTAL_PAGE_ID}cat_id={newsrow.newscol.ID}"><img src="{newsrow.newscol.THUMBNAIL}" alt="{newsrow.newscol.DESC}" title="{newsrow.newscol.DESC}" vspace="10" /></a></span></td>
<!-- END newscol -->
<!-- BEGIN news_detail -->
<td class="row1g-left row-center"><span class="forumlink">{newsrow.news_detail.NEWSCAT}</span></td>
<!-- END news_detail -->
<!-- END newsrow -->
I removed all the tables but I noticed it'll always display 4 categories on a row, then the text and then the other categories, no matter what I try to do.Where can I change the columns amount or remove it completely? Or will it affect the whole display and linking of categories?
Thanks in advance
Inactive User
Subject: Re: Change Columns In News Categories
Could be that you're in the wrong place, or you're dealing with something that's either nested, or maybe controlled by a php file.
Post a pic of what you are actually trying to change. ;)
Tell me what you want to do and I'll tell the best way...
If you want to remove the table there and use UL or DL you can just use these one after the other:
<!-- BEGIN newsrow --><!-- BEGIN newscol -->
Same for blocks end. :wink:
Generation Time: 0.082s (PHP: 19% SQL: 81%)
