Problem With User Management In APC
Subject: Problem With User Management In APC
I seem to be having an issue with managing users in the APC.
Under Users - Manage, I select a user and then try to make a change to their profile. When I click on Submit, I do not get the information page that says the change was successful and it just drops me back to the initial user manage page. No changes are made to the profile.
I can do things like change the user post count through the change postcount link under users.
Can someone shed some light on why this might be happening? If nothing else, which files should I be looking at that would control this function?
Thanks,
Chris
Subject: Re: Problem With User Management In APC
is it fresh install of phpBBXS ?
difus wrote: [View Post]
of course not... :LOL:
I know... I know... I guess I just need to know what files control the action described so I can see what I screwed up.
I'm not thinking that your files are bad
adm/admin_users.php
maybe it is database problem
adm/admin_users.php
no problems wit the database..
the problem was with the firefox password fix mod (http://www.phpbb.com/phpBB/viewtopic.php?t=364780)
Something in the 2 template files that need to be edited was causing the problem. I removed the fix until it can be fixed and everything is back to normal..
Thanks!
The fix for firefox autocomplete in XS is here:
http://www.icyphoenix.com/viewtopic.php?t=514
Note: replace every occurence of $HTTP_POST_VARS with $_POST ;)
Generation Time: 0.3283s (PHP: 8% SQL: 92%)
