SOLVED Where Is UPI2DB Switch
Subject: Where Is UPI2DB Switch
Hi
I´ve searched all my ACP to find the switch that enables UPI2DB select for users, like here
dibujo1_1249241768_339759
In my page it does´nt turn up with UPI2DB turned on
dibujo_1249241849_550814
anybody´s got a clou ???
Subject: Re: Where Is UPI2DB Switch
First, it's enabled in the ACP via a master switch:
ACP>Configuration>unread posts
It's the first one at the top where you decide to activate it.
Then if you activate the radio button "for users", then it can be turned off and on in the user's profile.
Profile>preferences> now it's at the bottom of that page where you select your settings.
I'm trying by the way to get it just to show the number by the "New" link in the header bar........I'm not having any luck.
:mrorange:
If you switch off
ACP/config/icy-phoenix/DB-Otimization second option
thats the main switch
It only shows new then
Thanks Spydie. I meant to let you know it worked earlier, but forgot. I have mine with same settings as here (MG).
:mryellow:
Generation Time: 0.092s (PHP: 18% SQL: 82%)
