Hi everyone. Until now i only found out how i can create cells, but not a proper table inside of a posted message. Can somebody help me?
Edit: you can close this subject, i found out how to activate html, so i can post tables now :)
SOLVED How Can I Post Table Inside A Message
Subject: Re: [SOLVED] How Can I Post Table Inside A Message
We don't close subjects if there is no reason for that.
Maybe can I the link or post how you have done that with the cells for other users that searched to the solution.
BTW: I have a tag behind your title set.
Good luck
Good luck
The problem is, we transver our forum to Icy Phoenix 1.2.0.27c! There we have some posts with html:
example: h**p://***.computerguard.de/abylon-...oad-vt7211.html
I search for a solution to "activate the html". But I don't found something.
I would be very happy for you help.
brandsrus wrote: [View Post]
the actual version of IcyPhoenix is 1.3.0.53b
think about upgrading again, since support for .27c is almost dead
Subject: Re: How Can I Post Table Inside A Message
I think he did that to avoid convert problems, I recognize the board related to an icyphoenix.de post :wink:
abylon, you can enable html in ACP
But it is a security think to use BBCode
In later IcyPhoenix version there is a option: HTML only for admins :mricy:
EDIT: By the way, you have reactivated a 2 year old post :roll:
Thank yopu for your help!
... And sorry for open an old post... ^^
Hi TheSteffen,
I heard you help us during the update.
I've now hearded that you help us with the forum-update. Thank you very much for your support.
Of course, I know that html can be dangerous. Therefore, it should be possible only for special single-user. I'm a supportler and I need it to integrate my product page as an "iframe" in the post. Other html-code I don't need actually.
Again, many thanks
Thomas
TheSteffen wrote: [View Post]
Hi TheSteffen,
Again, many thanks
Thomas
Generation Time: 0.0621s (PHP: 28% SQL: 72%)
