Post Getimagesize Function Doesn't Works On PHP 4.4.2
Hi to all. I have found a bug in the 4.4.2 version of PHP and the getimagesize() function. The discussion, in italian is here.
http://www.phpbbplus.it/phpbbplus/s...rto-vt3329.html
Another important discussion in english is here
http://codewalkers.com/forum/index....6&realm=default
MG can you translate some important part of italian topic and move this in How to? I think that could be important for a lot of users... Sometimes I have read problems with images in the posts.
Post Re: Getimagesize Function Doesn't Works On PHP 4.4.2
Andrea, in next XS you should be able to use an alternative way of resizing images... and this should work better than Limit Image Width, even if still related to getimagesize.
LIW is causing several problem with page loading... but as you can see here on this board... images are still resized, but loading is much faster.
Thanks for your report... I'm going to check both discussions when I'm a little bit "awake"... now it's 3.26 AM!
