Cannot Enable UPI2DB
Subject: Cannot Enable UPI2DB
Hello again....After the upgrade to 1.3 upi2db is not working
I've enabled the 2 switces on from IcyPhoenix>SQL Optimization and the other from the "Unread Posts"
I hane it set to enabled not to user defined and even if i can see the switches to my overall_header.tpl menu i cannot see the additional marking for unread,permanent read etc...
Some sample code from nav_quick_links.tpl
<!-- BEGIN switch_upi2db_on -->
<li><a href="{U_DISPLAY_U}" title="{L_DISPLAY_U_S}">{L_DISPLAY_UNREAD_S}</a></li>
<li><a href="{U_DISPLAY_M}" title="{L_DISPLAY_M_S}">{L_DISPLAY_MARKED_S}</a></li>
<li><a href="{U_DISPLAY_P}" title="{L_DISPLAY_P_S}">{L_DISPLAY_PERMANENT_S}</a></li>
<!-- END switch_upi2db_on -->
Is it a known bug? Is there anything wrong with the switces or i missed something during the upgrade ??
Thank you very much !
Subject: Re: Cannot Enable UPI2DB
Did you do the quicksettings in ACP ??
I had something similar with the post´s. just got empty pages after upgrade.
did the quicksettings and everything started to work
Yes i did....I have now selected fast & furius....
I tested now recomended and full setting but no luck....
I worked just fine in 27c...
EDIT. Can i enable it manually?
Does the rest of your forum run fine???
I suppose.....yes! why?
EDIT: should i execute db_update_000.sql ??? Is it safe?
When you updated your site from .27 to 1.3 did you run DB.update ???
I followed the installation instructions....
Witch is the safest way to update the db? :(
Sorry for doubleposting....Is there any routine to update the database to fix it?
I have tried all methods from guicksettings but no result....
i am in front of a dead end... :(
EDIT: O.K. i just found that it didn't work because i had my site disabled from ACP... I enabled the site and everything works fine !
Soorry once againn :(
no worries glad you sorted your problem out
:mrgreen: :mrgreen:
Generation Time: 0.0622s (PHP: 29% SQL: 71%)
