grafnap
 Closed Dyn Menu Categories - Links?
hi all,
i need help as i would like to have my categories links in my dyn menus always closed,
since i have many links in menus, instead of when someone comes to site they see all
opened ... thanks.
#1 Thu 27 Aug, 2009 23:56 |
spydie
 Re: Closed Dyn Menu Categories - Links?
I think that i´ve read something about this issue , but i don´t remember where that was.
Have you tried running a search for nav links block
____________ Out of Order
#2 Fri 28 Aug, 2009 00:18 |
grafnap
yes, i always search first to avoid looking like a idiot, LOL ... sometimes
i spend hours in here just searching, LOL...
ok, i think the appropriate term to use is minimizing the dynamic menus
so only the categories are seen and not all the links inside ...
#3 Fri 28 Aug, 2009 00:41 |
spydie
i think i´ve seen that issue in an template discussion but i´m not shure
#4 Fri 28 Aug, 2009 00:44 |
grafnap
ok then, since this is very important to me, i will try to keep this opened
because i really would like to solve this problem...
so if this cannot be corrected, then does somebody have
suggestions for another idea? ...
i have seen there was drop down post for nav link, but
i did not find the codes to change and will it work for dynamic menu?
thanks all in advance for all your help.
#5 Fri 28 Aug, 2009 15:50 |
Chaotic
Are you talking about the drop-down menu for Icy Phoenix?
If so, the block is called global header [Global Header].
#6 Fri 28 Aug, 2009 18:52 |
spydie
nope.
Talking about Quick_nav_link´s block.
i think i´ve read something here talking about a code change so the block is closed when you entyer the page.
not all open (with all links show´n)
#7 Fri 28 Aug, 2009 19:15 |
DWho
that's a cookie issue.. with the block...icy1.2 had it closed by default ...
i do not know if MG changed it so it was open for 1.3
i did have a look a little while ago but got distracted with something else...
i think a member here who does templates had it set to close on his templates maybe he will help.. if MG does not see this first
#8 Fri 28 Aug, 2009 19:20 |
grafnap
yes, I would like it set closed as default, this is for Dynamic Menus, not Nav_Link Menu ...
DWho, if you could find out the person who had it set to close, i could ask him/her ...
thanx again.
#9 Fri 28 Aug, 2009 21:33 |
spydie
i think you should ask elpulgas
if i´m not wrong it was him
#10 Fri 28 Aug, 2009 22:45 |
elpulgas
No, I tried but didn't succeed =(
What I did was take the JavaScript from it to use it on a quicklogin tab. However the tab is open by default even if I don't use the cookie.
Sorry but I can't help much and I'm kind of in the same problem. You can ask Lopalong since he had a working code for something similar
____________ KnekZ
* html body {display:none;}
#11 Sat 29 Aug, 2009 00:15 |
spydie
But i´ve been right , i´ve seen this issue in one of your posts
#12 Sat 29 Aug, 2009 00:29 |
elpulgas
Well I can only remember that one. Maybe I created a similar topic on how to do it. A question:When you see my site, are they closed or open?
____________ KnekZ
#13 Sat 29 Aug, 2009 00:44 |
spydie
closed i would say
this is a view
#14 Sat 29 Aug, 2009 00:54 |
Inactive User
Put this file in the theme folder you are using - Edit it to suit whatever you want to add or remove.
Note: You will no doubt need to change all the old block vars to the new constants used in IP1.3
These for example:
<!-- BEGIN mg_switch_user_is_admin -->
<!-- BEGIN switch_user_logged_in -->
Etc, etc.
Description: |
 Download |
Filename: |
nav_quick_links.zip |
Filesize: |
2.23 KB |
Downloaded: |
218 Time(s) |
#15 Sat 29 Aug, 2009 01:06 |
