[SOLVED] Content Encoding Error In Forum.php
Subject: [SOLVED] Content Encoding Error In Forum.php
I upgraded to 1.3.0.53 and almost everything seems to work fine now, there is one major problem.
when clicking on the forum (forum.php) it gives me an content encoding error.
I can browse to topics and subforums using specific links, however forum mainpage gives me this error.
Tried it with 3 different browsers on 2 machines, so that doesn't seem to be it.
Anyone an idea?
http://shibaforum.nl
Subject: Re: Content Encoding Error In Forum.php
Two solution:
1- disable GZip compression, manually
2- -open includes/page_tail.php
--Find
  1. if(function_exists(ob_gzhandler) && $board_config['gzip_compress'])
  2. {
  3. ob_end_clean();
--Replace With
  1. $gzip_compression_activated = false;
  2. if(function_exists(ob_gzhandler) && $gzip_compression_activated)
  3. {
  4. ob_end_clean();
Since backoffice worked I didn't have to do it "manually" (if you meant in DB)
Diabled it and voila! thanks!
Up to the next (minor) problems.
Generation Time: 0.1002s (PHP: 28% SQL: 72%)
