hi!,
I need some help to clarify some doubt before IP upgrade......
Upgrade From Old Icy Phoenix Versions
10.Remove the following folders (make sure you don't have in those folders some files you may need for some mods you have installed, but in any case you should have a backup Backup Rules!):
* adm
* includes
* language
* templates
In here MG means Remove above Directories know ? then what happen to other folders (block,cache,cgi-bin)?
11.Remove all files but config.php in your Icy Phoenix root (make sure you don't have some files you may need for some mods you have installed, but in any case you should have a backup Backup Rules!).
in here MG means .. Remove all files without config.php file ? or anything?
12. Upload all Icy Phoenix files (all but config.php) in the same folder where Icy Phoenix was installed and running. Pay attention that all older files eventually still there must be replaced by new ones.
in here MG means Upload new IP files without new config.php file ? and all icyphoenix files means with or without directories(only login_ip.php like files) ?
In the Boxes
hampshire
