Error Installing Theme
Subject: Error Installing Theme
hello all, I imagine this will go here and i'm sorry for my english.
My problem is this, is that I have tried to introduce the theme in my Icy, fk arancio and left me the following error:
DATA SUPPORT:
URL: http://www.finalanime.es/
Template: Milky Way, the base.
MODs installed: none
Icy Phoenix version of phpBB: 2.0.27 (I think it was that I'm not sure)
Server: Payment
If an upgrade from another version of Icy Phoenix: not updated
If an upgrade from another version of phpBB: no update
If a conversion from another type of forum: no
Now I can not access my website in any way and is also, I had the "brilliant idea" to put this theme for all users and I forgot to turn off the option of "ignoring the theme chosen by the user.
I deleted the theme of FTP, gone to the DB and changed the value '31 'is the theme for that by the '28' which is the milky way that corresponds to the table 'config'. In addition to erasing data in the table theme 'themes'.
After that, I cleared cache and reloaded the page, seeing that everything was the same I have a copy of my BD and I have asked the service of my host put me one more updated than I had previously (3 months ago is my copy) and I have not made a backup before installing the theme because I did not imagine that I was going to happen.
What can I do?
Subject: Re: Error Installing Theme
look´s like your trying to install a Icy 1.3.0.53 theme in icy 1.2.0.27
that want work.
upgrade your forum to icy 1.3.0.53 first
but i can't install 1.3.0.53 version because my server not suport file editions.
There is a doc for update ....
"[DO A BACKUP !]
Delete all file but config.php and upload all files but config.php and run install/database_update.php" (my fast version)
ok, i try it.
I intent to install and i see that:
Continue with the progress and:
Did you succeed or are you still having problems?
Generation Time: 0.0852s (PHP: 20% SQL: 80%)
