Modification - Merge Double Or Last Posts By The Same User
Here's a handy little MOD that's a lot more friendly than the bump restrictions currently used by Icy Phoenix.
Package Icy Phoenix Modifications
File $Id: double_post_merge-en.txt
Version for Icy Phoenix: 1.3.0.*
Author: Mercuree ( Igor )
Copyright (c) Mercuree
Email:
License h**p://opensource.org/licenses/GPL-license.php GNU Public License
Extra credits for this MOD:
Extensively Modified for Icy Phoenix by Lopalong. 28th September 2009
Title:
Double post merge
This mod merges post text on posting to the last message in topic instead of adding a new one, only if the poster of the last message and the poster of current text is the same person (double post becomes one post)
Re: Modification - Merge Double Or Last Posts By The Same User
I think Lopa already coded it to be an extra addon with only two small edits in core files.
I agree MG,
There comes a time when one has to really evaluate what should be added every time a user suggests something should be.
@Daniel,
No offence - But if everything was added that every user would like to see as a default application - Icy Phoenix would need two men and a boy just to lift it.
OT:
@MG,
I've got another one for you too that I'm about to post. Maybe you would like to run an eye over the code before it's "Officially" released.
And don't give me any MG_VIEWTOPIC stuff as viewtopic.' . PHP_EXT works just fine!
Yes, i understand you Lopalong and MG..
But i was thinking on it because MG said that will remove some unused features in IP, so, i think this is a good and small mod..
Anyway, there is no problem, i frequently visit this page and i can install the mod if i want (in next releases)..
Hi
I have a problem with this mod as you can see from the image below (not sure where the nn has come from) :-
however I think it might have something to do with my Slash Problem what do you think ??? have I done the mod wrong or am I right and this is a knock on effect of the my slash problem ???
And:
Is Not:
'L_CLOSE_WINDOW' => $lang['Close_window'],
Is:
"L_CLOSE_WINDOW" => $lang['Close_window'],
What Rubbish!
So long as the encapsulation is the same on both ends, quotes and semi-quotes mean the same thing.
And did you take the time to read the other posts where people have installed it and don't have this problem?
Did you also note that it appears only n1cks21 has problems with slashes (For whatever reason) and this is hopefully a fix for that particular problem.
The time now is Sat 11 Apr, 2026 15:34 • All times are UTC + 1 Hour [DST enabled]
