SOLVED CMS Default Link For Dyn Menu
Subject: CMS Default Link For Dyn Menu
Where can I found default links list for Dynamic Menu?
Subject: Re: CMS Default Link For Dyn Menu
Do you still have the default menu that comes with Icy Phoenix?
Check CMS -> Dynamic Menu. Do you still have the default menu there?
Chaotic wrote: [View Post]
Yes, I know it ;)
but I want to edit them...is it possible?
I want to change default link for new messages
You can edit any and all links in your dynamic menu. Is this the first time you are using the dynamic menu? You'll love how easy it is to edit the menu over the site links block. :)
no, no....sorry for my bad english... :mricy:
I want to edit the default link for "New Messages (x)"...
In "CMS->Dyn Menu" I only can choose one of them, but cannot change url for everyone. I want to change it... :( I think I have to modify some files...
Hum, I don't know if the link is hardcoded :s
Try to check includes/constants.php, but ... I'm not sure ^^'
lang_dyn_menu.php
No sorry MG, I want to edit its URL... :P
functions_cms_menu.php
thankssssssssssss 8)
Subject: Re: [SOLVED] CMS Default Link For Dyn Menu
uhm....no! :?
I would like to change the default link for links.php (not only name, but URL also).
where is it?
FOUND IT: default! :mricy:
and where can I found links for menu images?
Generation Time: 0.3767s (PHP: 12% SQL: 88%)
