SOLVED Problem With Overall_header
Subject: Problem With Overall_header
On my website I have two sponsors, the only way I can put your banners are put on each other (see picture), what I want is that the two are followed, that does not occupy much space. What code I put in the overall_header?
Subject: Re: Problem With Overall_header
Ok... how did you add those banners? Through ACP feature or directly in overall_header?
If it's through ACP feature please provide the code you added.
If it's through overall_header please provide the sourcecode of that file.
Greets!
Greets!
I add directly in overall_header.
The code is this:
The code is this:
<tr align="center">
<td>
<table align="center" width="100%" border="0">
<tr align="center">
<td>
<br />
<table width="468" border="0" cellpadding="0" cellspacing="0">
<tr align="center">
<td width="468" height="60" valign="top"><a href="http://hospedaje.grito.net" target="_blank"><img src="http://www.grito.net/images/duermef.gif" width="468" height="60"></td>
</table>
</td>
</table>
</td>
<tr align="center">
<td>
<tr align="center">
<td>
<br />
<tr align="center">
<td width="468" height="80" valign="top"><a href="http://www.xipnet.es/" target="_blank"><img src="http://i43.tinypic.com/izrsdi.gif" width="468" height="80"></td>
</table>
</td>
</table>
</td>
<td>
<tr align="center">
<td>
<br />
<tr align="center">
</table>
</td>
</table>
</td>
<tr align="center">
<td>
<tr align="center">
<td>
<br />
<tr align="center">
</table>
</td>
</table>
</td>
Try to replace all the code you posted with this:
Greets!
- <tr align="center">
- <td><a href="http://hospedaje.grito.net" target="_blank"><img src="http://www.grito.net/images/duermef.gif" width="468" height="60" /></a> <a href="http://www.xipnet.es/" target="_blank"><img src="http://i43.tinypic.com/izrsdi.gif" width="468" height="80" /></a></td>
- </tr>
Greets!
Generation Time: 0.2727s (PHP: 6% SQL: 94%)
